dwoffroad said:
I have a Trek 4100 with an Altus rear derailleur. I recently spent some time trail riding and consequently plowing through some deep mud - almost up to the bottom bracket! After I was out of the muddy section I notice my chain was making a lot of noise on the down stroke while pedaling hard. I later cleaned up my drive train and re-oiled with Tri-Flow, but the noise stayed. I've adjusted the rear derailleur as shown in my repair manual, but I just can't get it to quiet down. It shifts like a dream - no skipping, no mis-shifts, etc.... Could I have twisted the cage or otherwise damaged the derailleur just by going through the mud? Please help!!
Mud is bad. Water is bad.
Mud can help create lots of wear on your chain, on your cassette, on your rims (if you don't have disc) and on your rear mech.
If the bike won't quiet down it could be any one of the above parts, or even your hub or Bottom Bracket that might have lost lubrication (grease, oil, whatever) and started to make noise.
That's the bike reason not to ride in mud. Now for the soapbox part. If you're riding where the BB is almost engulfed by mud, that is a very serious mud puddle.
What type of tire ruts can this cause, what type of damage to the trail? Riding in mud is bad, it leaves a water channel that doesn't want to drain, it damages the trail, and it can help cause the trail to widen. Riding in mud leaves a pretty permanent mark on the trail saying bikes were here, and it can, has, and will be used against us when we try to open new trails.
Best way to keep the bike working good and the trails in good shape too is not to ride muddy trails.
JmZ
