http://www.parktool.com/repair/readhowto.asp?id=64Victor101 said:when shifting to higher gears, the chain keeps coming off the lower cog. And skipping What needs to be adjusted? Thanks
After google'ing its the tension pulley, where the chain falls of track when shifting to high gear
This is a pretty good idea. I developed a ghost shifting problem after cracking and replacing a derailleur hanger. Had the derailleur adjustment checked at my local shop; no problems apparent. Back on the trail, the problem came back, big time.AzSpeedfreek said:Take your bike and a 6pack of beer to your LBS and ask them to show you how to adjust the derailleur:cornut: .
Im going to try this too.dan0
all you need to know
sounds like bent hangar, easy and cheap to straighten or replace, good to have a spare in your camelback too. check the hanger first , then adjust deraillier if necessaryVictor101 said:Parts are newish~ about 4 months old. I upgraded from alivio to deore components And yes they gotten abused in the sense that I ride alot about 65-70mi per week. Some crashes nothing major. Cassette looks ok no bent teeth, chainring aswell.
+1:thumbsup: best $40 I spentagabriel said:I think its important to note that even a new hangar might not be straight for your bike. I would suggest you either get the tool or bring it to the bike shop, if you ride off road alot it will be less expensive to buy the tool.
