I've seen quite a few good deals on Ebay for both Sram X.0 and XTR rear derailleurs, but many of them of GS, SGS, long or short cage, high/low normal or high rise. Which of these are compatible with the Rush and would work with a 2x9 setup?
Not only manufacturers but in Shimano's case, Low or High Normal...damion said:If you are going to run a 34T cogset, use a long cage der. Other than that, what shifter are you planning on using? That decision is going to determine what mfg you will use.
If you prefer X.0 twisters, go with them and a get a X.0 rear derailleur. Stay with a long cage if you use a 11-34 cassette and a 44T big ring. Medium cage derailleurs work fine if you go 2 x 9 but by taking off the big ring, not the small one. And they are not much lighter anyway.TalonSL said:Well, I've actually decided that I will go for whichever derailleur works best for the 2x9 system I want to run. Dan, I believe you recommended this because the bike will be around 25 lbs or so when complete. If I could use any shifters, I would choose the X.0 twisters, but I know that requires using the X.0 rear derailleur. I've heard various opinions about high or low-rise, with some claiming that one causes less wear than others. I lso thought that maybe going for a sharter cage ould save some weight, but probably not much.
you just an not use X type twisters.TalonSL said:Thanks Dan. I've found a few X.0 derailleurs on Ebay pretty cheap, and I'm bidding on some twister shifters. We'll see if I win those. It's too bad you can't run Shimano derailleurs with Gripshift anymore.![]()
