I'll be taking my 29er to the Himalaya. I'm 195 with small backpack and water and bike will weigh 45 or so when loaded. I'll be away from any sort of bike store for the entire trip. I'll have some needle and thread and boot material, some extra sealant but figure I should start with really strong durable tires. Weight is pretty important so I'd like to avoid bringing a spare tire. If I can't keep the tire going then the riding will be over. Maybe I will bring a light tire for emergency. Dunno.
Rims are stans flow ex3 29, 29mm internal. Rear of frame doesn't look like it can tolerate a tire much bigger than a 2.25 ikon, which is bad because the rim is already too wide for that tire. Edit: Front has a 2014 float32 fork. I'd like the biggest tire there that will fit. Anyone know?
I'm looking for a light supple good rolling tire that is also good over loose over hard and is intensely durable. Ha. Place is a desert so loose over hard. Lots of loose.
I found these videos of some crazy Russians that did the same route in 2015.
Probably total distance is about 1000km, 800 or so is either bad dirt roads or really bad trails like in those videos.
I normally ride Ikons and the Vittoria Mezcal. The mezcal has been amazing, grips better and seems more durable than the exo ikon.
Is there a maxxis EXO+ tire that would work?
Minion SS in doubledown?
What do you guys recommend?
