aussiemegs said:
I just bought my Specialized Myka Expert about a month ago and for the last 2 weeks it has been shifting horribly. I took it to the LBS that i bought it from and the guy looked at it and told me nothing is wrong. But that can't be right because i have to go down 2 to actually shift down a gear and it is the same when shifting up. Then on top of this it is at times just shifting where ever the hell it likes which is annoying when going up a relatively steep hill and it decides to shift from 5th(my preferred climbing gear) to 9th.
The auto-shifting from 5th to 9th has me puzzled. That's quite a big jump!
Aside from that, when you need to shift twice to shift one gear, that suggests gummed up cable housing. However, your bike is relatively new. Have you ridden it through water or in muddy conditions? Have you crashed or fallen so that the bike has landed on the drive side?
Anyway, here are some things to check:
1) Dirty or gummed up cable housing. If the cable doesn't slide freely through the housing, it won't shift well.
2) Sharp bends or kinks in the rear derailleur housing. Given that your bike is new, this is a stronger possibility than #1.
3) Bent derailleur hanger. This could have happened if you fell on the drive side, or perhaps even if the bike were laid down on the ground on the drive side.
4) Poorly routed or poorly sized rear derailleur housing. If the derailleur housing is routed under the bottom bracket or in such a way that the housing can be partially pulled out of the housing stops on the frame during suspension compression, then this can be a cause for the auto-shifting that you're experiencing.
5) Frayed rear derailleur cable. A frayed cable create a lot of friction at the point of the fraying, leading to weird shifting problems.
