but first sorry for the Ingles, gets even wrost when i'm trying to explain something techical.
not exactllly in the subject of Reach, but for sure a great way to improve on power and some how modulation...
think about this for a second.....
out of the fingers in your hand, think about witch ones provide the most power..?
also look were you fingers are ussually place on the brake levers...?
well i work on bicycle shop and around bicycles and motorcycles for many years and is very seldom when i found a bike set up the "proper way".
In short your index and middle fingers are not only the longest but also the strongest and the most develope for continuos operation, the problem arrives when most hands can not reach the very extreme end of the levers (ussually levers are not extremlly well design in terms of ergonomics) and end up engaging the lever with their fingers near the folcrum point (pivots) were is very little leverage but at least the lever is the closes to your fingers..
my pragamtic aproach is actually to move the levers to a place on the bars were you have no other choice but grab the end of the levers (the end of the grip let you know when is to far) this is ussually about 1 1/2' from the end of the grip for my 6.2" proportional hands, if your hands are smaller, less distance will be require.,
something like this were you fingers are at the very edge of the lever were you find the ultimate leverage and also your two main fingers are doing the job..
actually I build my tandem with 4 brakes set up, two Rim brakes ussing V-brakes and also two hydrolic disc brakes to prevent rim overheating something very comun on tandems.
I set up the two levers (on each side) on a way they can be actuated independentlly or at Unison .
here is a view of the overall set up.
and here are the two brakes used at ones with only ONE finger on each of them at the very end of each lever providing a incredible amount of stoping power feedback, modulation and also efficiency of motion making you far less tyred at the end of a ride..
this is for sure a side subject when you are taking about reach, but is also something very important to keep in consideration since many people ride their bikes with very ineficient set up and waste incredible amount of energy in the process..
I hope it helps, maybe I just need to write my own posting about Biomecanical improvements.
