I just re-packed my rear bearings (and replaced the ball bearings) on my Shimano freehub using Pedro's Syn Grease. After everything was back together, I no longer had the signature "clicking" you normally hear from this freehub system. It isn't just quieter, the clicking is completely GONE. It seems to function normally -- the wheel turns smoothly and it engages normally when pedalling -- but I'm wondering if something is wrong, or if perhaps I used too much grease when I packed the bearings, and the grease found it's way into the inner freehub assembly.
Is it even possible to use too much grease when packing these bearings? I basically just filled the cup/cone area so that as I was re-installing the axle, some grease squeezed out around the cone (i.e. the cup/cone space was filled.) I thought this was normal, but the end result clearly effected the freehub mechanism, so now I'm not so sure. I've ridden it a bit and spun the wheel quite a bit on the stand, but it's still essentially silent, which I've never experienced before with this wheel (although this is the first time that this particular wheel has been serviced/re-packed.)
Is it possible for grease to get into the freehub by putting too much around the bearings? I would have thought that any extra grease would either squeeze out around the cone, or squeeze into the hollow area inside the hub, but I didn't think it could squeeze into the freehub mechanism. Is this not correct? I did not remove or disassemble the freehub, and I thought that only a much thinner oil could get into it, but once again, the behavior suddenly changed after the bearings were greased.
On a possibly related note, as the wheel is spinning, I sometimes hear an odd noise coming from the hub area. It's hard to describe, but it sounds "sort of" like a grinding noise -- sort of a "deeper" grindy-clicking that does NOT sound like the normal freehub clicking. I should note that it does not sound like a "wheel bearing" grinding noise -- it sounds more like something in the freehub. It aligns with the frequency of the wheel turning, and it comes and goes -- I can't get it to happen on demand. I'm honestly not sure what to think. As I said, everything seems to work normally, but these two "sound" issues have me concerned.
Thanks for any feedback on this,
Larry
Larry
