RE: Need help with a rear shock on a '98 litespeed Unicoi (YBB)
Everyone,
I just bought a '98 Litespeed Unicoi off of Ebay for my wife, because she wanted a MTB with a softer ride. I am now in the process of rebuilding it. When I took apart the rear shock, I was expecting to see a Moots style YBB design. But, that is not what I found. I did not see (https://moots.com/wp-content/uploads/TECHpaper_YBBshock.pdf) the spring or the urethane bumper inside the spring, or even the Black Plastic Spacer.
Instead of these parts, I found a robust, 4-inch long by 7/8-in diameter aluminum pipe with a wall thickness of approximate 3/16-inch.
Does anyone know if this is correct? Or, did someone try and convert this bike to a hard-tail mountain bike?
I called Litespeed. They said that they don't support it anymore. I called Moots, and they said that they don't know anything about it, and therefore could not help me.
If this is supposed to look like a Moots, does anyone have some dimension on the plastic spacer, spring and urethane bumper that Litespeed used? I would really appreciate it so I can look for replacement parts.
Or if someone know someone who makes a conversion kit to a Moots style YBB. I would really appreciate that information, since they do support their bikes.
Thanks in advance,
David
Everyone,
Thanks in advance,
David
