you could take frame in to the house, (warm house), and throw fatty into the snow for a hour or two. then try to fit it.
with fatty locked out apply body weight to crossbar, hold the fatty vertical, and rock a little, front to back, helps if your a big lad. it should gradually ease on.
or you get a big hammer, bigger the better, and a piece of wood. place wood on top of upper bearings, then gently tap evenly around. it's important not to loose your patience at this point.
