Hi all,
Im about to be a proud owner of Revel bike.
Im building up Ranger frame now, swapping parts from my current Stanton Switchback TI (shift a little toward longer ride, less park DH....).
I now noticed below info on Revel HP.
For those who use Shimano crank sets, can you pls show how much the clearance is with the frame, using off-set chainring ? Anyone faced any issues using the recommended chainring ?
I trust Revel info, but just would like to see how it really works as it seems 3mm offset is not enough ?? to clear chain rubbing the rear triangle.... just to be sure...
If no issue, I will order wolftooth ring right away !
Thanks !
Yugo
---quote from Revel HP--
A known clearance issue exists between the mounting bolts on Shimano XT M8100 / SLX M7100 chainrings and the Revel Ranger frame. If you plan to use a Shimano XT or SLX crankset with your Ranger frame, you will need to use a 3rd party, direct mount chainring with Boost spacing (52mm chainline, 3mm offset). We recommend the 32t Wolftooth Direct Mount Chainring for Shimano Cranks.
--unquote--
Thanks !
Yugo
--unquote--
