So ive had couple of rides with the new linkage and a 170mm fork on my Rallon.
As stated in a previous post, i was disappointed that they sell the whole kit when you really only need the 2 side plates. Everything else in the kit is identical to the original.
But i can honestly say it has improved the bike and im so happy i did it. Ive been struggling to find the feel of this bike but now i feel one with it.
Its retained its lively pop but given the rear a little more plushness off the top and smoothed out the rear completely.
Only thing i changed was added 20psi to the shock (Float X2) and removed 1 volume band.
Nothing has changed on the clickers yet.
Also check your rear axle bearings, mine were pretty much seized. The rest were ok.
One other change ive made was go to a 50mm stem and the longer offset 51mm fork.
For my height 6'2, having the wheel further forward and more weight over the front made a noticeable difference for me.
Maybe with 10mm more reach in the frame, i could make a 40mm stem and 44mm offset work. Currently my bike is dialled and has me frothing for the first time in 12 months.
