21 - 40 of 133 Posts
miamimitch said:
Make sure you go slow and light at first to make sure you do not injure yourself again.
Good luck on your recovery
Thanks Mitch.
Well at present it is slow and steady but I can't push it anyway. The response is always slow, the speed is slow and steady too. There are also movements which I can't attempt either so... there you go.
There is a slight increase in strength and some flexibility increased too - but the fragility is still evident when I move it or intend on moving it some more.
Cheers again. I'll let you know if things change.
4 mos and counting
Still working on my elbow after 4 mos. I do my own PT at least twice per day and I have it to about 90% movement and have started riding again. But it continues to ache constantly. The elbow seems to be a long road on the recovery.
Hi Griffin
Could you give a little more information regarding what kind of fracture you had please?
I'm about 70% movement, I'd say. Maybe I'm being optimistic. OK, 60% but I'm working at it and today I am a little more optimistic.
I'm trying to use it as much as is possible of light work and doing what exercises I've been told to do.
Thanks for replying mate and all the best.
Fractures
I was fortunate and didn't do a full displacement of the radial head. There were two 1/2" cracks on each side of it. They didn't put my arm into a cast and started me on light PT about 3 days after the accident. They also gave me a shot in the elbow to reduce the swelling quickly. I was at about 80% movement after the first 30 days. Since then it's been very slow getting the rest of the movement back. It does seem like a rollar coaster some days though. I'm betting about 6 months to full recovery at the moment.
Thanks Griffin
What you're saying is quite reassuring. I am going to be into Physio myself soon but in the mean time I am doing some movement and getting something back but I've also get pain too. I guess this is partly down to me pushing it since I want more movement back...
Cheers again. Finding out more about it gives some indication as to the nature of the injury and what type of healing and recovery is occurring.
Regards
187 said:
Flugu
I fractured my radial head in April 2008. I had two surgeries, one to screw it back together and one to remove the hardware. It is an injury that takes a while to come back from. I?o was about an inch away from full radial head replacement.
You will hear this over and over but it is absolutely critical, get into Physical Therapy and stick with it. My health care provider (Kaiser at the time) tried to tell me PT was unnecessary. I knew better and had my primary care physician order up the PT.
I have to really pay attention to my arm. If I slack off the exercise my injured arm will become noticeably smaller than my uninjured arm in a matter of weeks.
Good news is I'm back on the bike and with minor exception, I'm doing everything now I was doing before the injury. Let me know if there is more info I can provide.
JB
Hi there man
I was just wondering regarding your recovering.
I have seen some significant changes recently. I am out of the sling and can flex completely, almost albeit with some pain.
Extension wise it is a bit off still. I have been able to push it until it's 10 degrees off but that was with some real pain for a few days.
I was wonder then, how far are you with in terms of extension considering you were told it won't get back to that. I am starting Physio next week by the way.
Regards
I had the pleasure of radial head fracture myself:
2 months ago: Road bike ride. Brand new Look 555 with about 30 miles on it to replace my '93 Trek with 25,000 miles and 3 dozen races on it. A one-in-a-million chance of nicking a stick with my front wheel and putting it perfectly in the spokes. The carbon fork shattered and I went over the handlebars hard. Brand. New. Bike. Grrrrrrr.
Anyway, I put out my right hand for impact. Cracked the radial. That was 7/11/09. The orthopedic surgeon cut off the ER's cast and said no surgery - only PT. I did 6 weeks of PT and have pretty much all range of motion back.
I haven't ridden since the crash. I've been building up my new frame: Look 565 this time (there was a tiny patch of cracked paint behind the head tube of the 555 meaning the the frame was damaged in the crash.) and I'm also itching to take out the Stumpjumper.
Question to anyone else who had gone through this: How long until I can safely ride on the elbow? The doc said 2 months, but I work as a camera man and have put alot of weight/work on this arm in the last month - I don't want to over stress it any more. It is still sore and putting miles on the trainer definitely irritates it. Is the pain something to ice after a ride, or am I risking further damage at this point? I'm running out of DVD's to watch while on the trainer. (BTW - on the old reliable Trek.)
Well... do you still have pain in any form from it? If you do then I'd maybe wait a while although my Physio tells me the pain is not damaging all that much. It is still a weak area, well it is for me.
I had mine about 2 or 3 weeks after you and it still gives me bother. I've only had 2 weeks of physio yet though but it still has it's problem.
Have you really got full range of motion back? I mean without pain? You can fully extend it and flex and rotate it without pain and to every extreme? If so - then that is quite amazing.
Good luck with the riding. You could ask some of the guys here. Maybe go on some straight roads and see how it feels. Tie it up a little, I mean with some support. It should help.
You could try PMing some of the guys above for more advice.
Hi....regarding radial head fracture.
I am the mother of a racer from Seattle...first name of Tim.
Anyway, I thought maybe I could ask all of you about my radial head fracture.
8/22/2009 date of injury. hard cast for five days then half cast splint and sling that I used for two weeks, doing range of motion, palm up, palm down.... for past 10 days splint only.
I now have swelling again..just been using the sling...do you think I could have broken again?
A supportive mother of your sport
Wow......one week ago I had a (horrific) road bike wreck. Doing about 30, looked down for a second and veered into a curb. Went OTB and hit the ground where there happened to be a culvert, so instead of sliding along the pavement, I came to a rapid stop.
Lots of rash, and I learned two days later that I had a radial head fracture on my right. Doc said it was 1.5mm wide, looked to be about 1.5" long on the Xray. Same deal, no cast just work moving it. I am still in pain every day, but today was the first day without advil. I am probably working it too much. I hope to be back on the bike in 2-3 weeks, pending a good dr visit.
Range of motion gets better daily, but it is still quite painful to do palms up/down.
Also have shoulder pain now, should have mentioned that at docs office, but did not notice it with the arm.
Matt...just the same except how it occurred. I was sitting on the top of the steps at cabin and probably caught heel behind first step when I stood up....basically flew over five steps and landed directly on the concrete below...crossing my arm in front of me probably prevented worse injuries.
My fracture is identical to yours at 1.5 mm...slight distraction. My elbow did lock at 90 degrees.. that has improved.
It still hurts. still taking Advil. Hard for me to touch my face...It may have been immobile too much of the day in the 2nd week.. not sure. or maybe an age factor. Keep your fingers moving...and if you think your wrist hurts even a little bit have it x-rayed too or re- x-rayed if it already was done.
forgot to mention..see a PT..I did therapy on my own and think I probably pulled a tendon in my hand. Also, your should probably have your shoulder x-rayed. If you have a sling keep the elbow strap behind your shoulder and not in front...seems to help me with the shoulder pain.
Ya.....still can't come close to touching my face. I can finally use a spoon with my right hand though. Not easy...
How long did it take for you to get all healed up?
How old are you....I'm 25. Ill post back here after my return visit to the Orthopedic's office.
Matt. My son is 28, close to your age.... I am 56...may be why it is taking me longer to heal. My fracture was "healed" on x-ray at 4 weeks, but was told last week to still be careful, still no solid callus formation yet. I have hit my elbow a couple times and it scares me.
I am really sorry I did not insist on professional physical therapy and instead just had the orthopod say "do this do that, etc". I also have heard that occupational therapy is beneficial in helping to hold pen, etc.
Your accident does sound horrific, but I must say you are much further than I was at 1 week post injury. I find it hard to understand exactly how much exercise the MD wants me to do.
I will be anxious to hear what your ortho says.
Update on my injury:
I went on my first ride since my 7/11 accident yesterday. The ortho doc said no riding for 2 months following the accident. Even if movement is back and pain is down, that is alot of force going through that joint while riding. I'm a cameraman and work came up at week 5 that had me shooting for 2 straight weeks - that really aggravated it and I decided to add another 2 weeks to waiting to ride.
Patience. I'd rather do some time on the indoor trainer than risk compromising the healing process. My rides the last two days have been road rides and I'll keep off the mtb until another couple weeks, due to the increased amount of shock put into the arms.
Matt - I would definitely give it a lot more time than 2-3 weeks to return. The main instructions from my ortho and physical therapist were keep stretching, flexing, and improving range of motion - but keep all weight off it.
-Geo
I have to go out so will reply in detail when I return.
Leen - I don't think you've broken it again but only an Orthopaedist will be able to answer that. The swelling is normal and is basically the swelling covering the injury and also from movement (which you need to do to stop it getting worse).
If you are still concerned, then it is best to see the Orthopaedist. The Physio is more exercise and rehab based, the Orthopaedist can assess injury and stuff.
You can't keep x-raying because of radiation poisoning. I think you're supposed to have one ever 6 months only and only if it's serious you can have another.
The Orthopaedist or your Doctor could send you to somebody who could assess an injury without an X Ray.
-Geo
I haven't ridden and I don't think I will for a while. Winter is coming soon and I will also need to get my fitness back soon too.
It aches regularly. Most movement makes it ache - fast movement is not possible but when I do it struggles for a while.
I am thinking with what I've heard it will take probably months to a couple of years before I get any normalcy.
I also get a clicking sound too.
Yeeper.....Maybe my fracture was not as severe as yours....at least that's what I am hoping. The Orthopedic that I am seeing is a good family friend and has a really good reputation in the community. I am pretty sure he would have had me do PT if he thought the injury was bad enough. At least I hope.......
I'm having a hard time with it, mostly because I'm a farmer and a lot of my time is spent using that arm. I just hope I don't screw it up and have permanent limited range....
On a side note.....I run now that I can't ride, and nearly ate it today while running. I'd like to think I would have the presence of mine to pull in that injured arm, but I dunno. Luckily my feet caught me.
I'm not sure where you are in the world but in the UK your GP (Family Practitioner) will send you to a Physio.
I have talked to a lot of people regarding the injury and all of the guys I spoke to, told me to see a Physio and it has helped in a lot of ways.
I would consider taking this option and also talking to the Orthopaedist and later Physio about the work your are doing.
I put a bandage over my elbow by the way. I had a really strong bandage which helped support the arm while it healed. It does help.
