Having trouble getting ONE of my two RR's to seal. The water bubble test shows many fissures in the sidewall--none at the rim. I shake the wheel then lay it on the side leak side down for a few hours. Still no luck. The other is holding air fine.
Is it possible there is not enough sealant--I can't hear any sloshing, though some watery sealant come out of the valve when I loosen valve to fill with air. Alchemy built the wheels, so I don't know how much sealant Jeremy put in.. Or should I get another less porous example?
