Nice pics. Have you had any trouble with the shock?
That bike looks awesome, the black looks so much better than the yellow and the red dorados suit it perfectly. Have you got any pics of the bike by itself?andresanches said:Had no problems at all with the shock. Depending on the course I prefer a more supple suspension, so I then "open up" the settings. The geometry also helps with the "quality of travel".
I am around 215 lbs and have had no major problems with my SGS DH pro. Pretty stiff setup with the 12 mm thru axel. The only problem I had the bike setup a bit soft to start and bent the lower shock bolt by bottoming out. I would suggest upgrading the bolt to something of a higher grade right of the bat.thebigbomber said:Do you recommend this bike for someone 235lbs?
I don't think the bolt is really a problem with the bike. I weigh 215# and ride mine pretty hard. About the first week I had the bike I bent the bolt and Iron Horse immediately replaced it with a new upgraded part. It has a larger diameter/different bushing configuration and has held up fine for the past year. I'd take the SGS over a Stinky any day.thebigbomber said:some things that might be suspect on the bike? Or is the bolt a problem for any rider or just heavy ones. Tough decision. I think I will keep looking a bit.
