I know the net is littered with Raceface Dropper issues. Mine has worked fine for the past year. I stopped riding the other day and adjusted the barral adjuster ONE CLICK just to make sure the lever on the handlebar had the 2-3mm of play...and the seat popped up. Won't stay down now. The brake seems to be stuck where it will not engage. You can just push the seat down and it pops right back up to full up.
Heres what I did:
1.) I took it apart, adjusted everything properly according to Raceface troubleshooting. No luck.
2.) Put a new cable. Adjusted properly. No luck.
3.) Attempted to "reset" the brake according to Raceface. Nothing!
Has anyone run into this issue? It holds air fine. However the internal brake will not engage to keep the seat at a certain spot. It just goes full up.
There is zero info on the web regarding the rebuild of this dropper other than a small bit on re-lubing.
Any feedback would be great!
Heres what I did:
