a 9 speed will work with an 8, but not the other way around. Your good to go.allin said:i just bought a raceface prodigy xc crankset and the rings say it's for 9speed. can i use the rings with a 8speed drivetrain? if not, does anyone know where i can buy a new set of 8speed chainrings in a 4 bolt pattern? thanks.![]()
Thanks.Geist262 said:a 9 speed will work with an 8, but not the other way around. Your good to go.
Good point! Also, use some greese on the splines and USE a torque wrench.DiRt DeViL said:As mentioned below, you're good to go.
One comment, take good care of the threads. They're weak and can be damaged very easily, at least that's my experience with the Prodigy cranks.
I run those on my 8 speed bike and they work fine. You also may have to move the front derailler up to clear the top chain ring.Geist262 said:Good point! Also, use some greese on the splines and USE a torque wrench.
