68mm Bottom Bracket shell
Bottom Braket: 2 spaces on drive, 1 spacer on non-drive side
Cranks: non-drive - 4 white and 1 black; drive- 1 black +red seal
32t rear gear and 34t front gear (average climbing gear for me) the chainline is pretty sharp. Sharper then the same combination on another bike using square taper RF bottom braket, and RF LP turbine cranks.
It is by the book, and appears to work fine. I was considering removing a drive side bottom braket spacer, and shift a crank spacer from non-drive side to drive side. Should equile moving the line 1.5 mm toward the seat tube.
