I picked up a Race Face cinch PM for my Specialized Chisel, which is currently running Race Face Next SL cranks. Unfortunately, when I went to swap the spindles I found I was unable to remove the spindle from the non-drive side crank arm. I've removed the cranks from the bike, as the drive-side was easily removed with the self-extracting bolt.
My understanding is that I should remove the 16mm cap from the non drive side, throw in the 8mm self extracting bolt from the drive side, re-install the 16mm cap, and extract the spindle. Which seems to make sense, but I can't remove the NDS 16mm cap at all. In some frustration I used a long pipe to get some leverage and ended up stripping out the 16mm cap on the NDS pretty badly.
Are there versions of the Next SL cranks where the spindle cannot be removed? It's almost like this thing is glued in there - I had no problem removing the drive side cap. I'm considering drilling/cutting the cap out, but then I'm a little concerned that it wasn't intended to be removed and I'll have more problems when I try to use the self extracting bolt. Since the cranks work as-as (even with the stripped NDS cap), I don't particularly want to mess them up any worse than they already are.
My options are to cut my losses and sell the current crankset or to tear it apart and hope for the best. Before I go for option #2, was curious if anyone else has been down this road and knows whether or not some of these are simply not removable.
Tried to go to my LBS and they pretty much told me to **** off, and Race Face's support page tells me to go to my LBS...
