First, my apologies if this is posted in the wrong forum.
I've just been handed a 20+ year old mtb for an overhaul. After a little elbow-grease and acetone on the frame (somebody painted parts of it with a brush and oil paint), I can see it's a Maruishi (?) never heard of that. At least it's a chromoly frame
. I'll do the usual bearing re-packing, cable replacement, drive-train scrub down and so on. The wheels are reasonably straight, although the back one has a nasty flat spot.
A troubling thing about this bike is that somebody has trimmed the handlebars (or they used to be super narrow). They're too short, making for an uncomfortable riding position. My son's junior-mtb (24" wheels/13.5" frame) has wider handlebars than this bike. The bars are welded to the stem with two smaller tubes (looks like a triangle between the stem and bars). I'm thinking the whole stem/bar assembly should be replaced.
The part that's causing brain cramps is the quill diameter is around 21mm. I've been told that this was done briefly in the early days of mountain bikes, and that it's actually 21.1mm. Sheldon Brown's site claims it's really 21.15mm. I measured the stem itself at 21mm right on the money. Regardless, this size seems to correspond to old-school BMX bikes, which means that's all I've been able to find for a stem that will fit this bike.
Does anybody know of a simple adapter to take the 21.1mm up to a standard 1-1/8" diameter so a threadless stem can be used?
Better yet, is there such a thing as a reasonably light-weight 21.1mm quill stem that has a standard 25.4mm bar clamp? To keep the geometry the same, the existing stem length is about 130mm on a roughly 30 degree angle.
