So what is it exactly? Is it a rubber-friendly wet or dry lube? Does it encourage the tire to rotate around the rim at low perssures under accel/decel (not a big deal with UST, but a mechanism that can shear a tube's valve)?
Once it dries it is no longer a lube. The label claims "Fluid evaporates completely." Do not know what's in it. Nearly odorless.tscheezy said:So what is it exactly? Is it a rubber-friendly wet or dry lube? Does it encourage the tire to rotate around the rim at low perssures under accel/decel (not a big deal with UST, but a mechanism that can shear a tube's valve)?
Not sure. I seem to have lost an hour over the weekend!tscheezy said:"Nearly odorless." How much sniffing did it take to reach that conclusion?![]()
