1 - 2 of 2 Posts
Add a small amount of grease on the center-lock splines or install the rotors dry? The Shimano docs mention a torque setting but nothing about prep'ing the splines in any way. Thanks. - M
From what I know, and I do used Centerlock rotors, is that you shouldn't need to grease the splines, put them on dry. If you want more info contact your LBS.
1 - 2 of 2 Posts
