If you had a bike with a 3x8 drivetrain and were going to 1x11 drivetrain, what would you go with to give you a similar range of gears? Maybe short of the lowest and highest gear combinations, outside of what would be useable on the trail. It's for someone who is relatively new to mountain biking and just tends to stick to what has been working on her bike and has reservations about changing to something new. I know, due to recent conversations, that she likes the idea of switching to a 1x setup but is a little hesitant to make the plunge. I'm finishing up my new bike with a 1x11 on it and plan to let her ride it around a little bit to get a feel for it to make sure she likes it. In the meantime, I wanted to consult the brain trust and see what would give a comparable range, since gear combos aren't my strong suit. I'm relatively new to the 1x world myself, but I also use a narrower range of gears than she does.
Her current bike is a 3x8 with 22, 32, and either 42 or 44 in the front with an 11-34 in the back. I'll have to look again on the front to verify if it is a 42 or 44. Per my last conversation with her about gearing, it sounds like she typically uses the 32 tooth gear on the front for most of our trails, but on some of our trails that have more intense climbing she will drop down into the 22 tooth gear on the front. I'm not entirely sure what range she typically uses on the rear. I guess lets assume the whole range on the rear, unless that makes a difference, in which case I will ask her next time.
Thank you.
Thank you.
