I'm looking ahead to the next bike for my daughter.
She's currently on a Trek Superfly 26 and is about to grow out of it. It should last until the Fall (with a longer stem). The Superfly has been converted to tubeless, XR3/SE4 tires and a 28t chain ring, since day one.
Currently she's 5ft 0.5in and weights 90ish pounds.
I've been stuck in the quagmire of buying a bike for a growing human that actually rides. The only option out there at can 'grow' with a rider is a Guerrilla Gravity, but that's pushing 4k and truly overkill.
Trek's Fuel EX 8 Woman is still around $3500, however it comes with full GX Eagle, good suspension, i40mm rims (I think), dropper, 27.5x2.8 XR4 tires and more. Overall its a really good value.
By the time I get the bike my daughter will be around 95-100lbs, 5ft 1-1.5in and 12 years of age. Does anyone have experience with the Fuel 8 Woman's, Fuel 8's or Fuel 8 Plus suspension setup with a light rider?
The sizing chart calls out a small fits 5-0.2 to 5-3.8 and a medium fits 5-3.4 to 5-7.7. The specs call out some kind of knock block to prevent the fork crown from striking the down tube. Can I still bump up the stem to push the size closer to 5-5-ish?
A medium frame would give her the most room to grow. Opposite of the last question. Can a medium have its stem slammed to fit a shorter (around 5-2 ish) rider?
I'm not familiar with the Fox Rhythm 34 Float fork. I have found contradicting statements that the shock is adjustable. The small comes with a 120mm and the medium comes with 140mm. This question applies mainly to 'shrinking' a medium, how ever could apply to adding a little travel to a small. Are these different forks or can I swap the air spring to adjust the length?
Any other interesting knowledge tidbits about the Trek Fuel 8 Women's?
Fuel EX 8 Women's
https://www.trekbikes.com/us/en_US/...ntain-bikes/fuel-ex/fuel-ex-8-womens/p/23602/
Fuel EX 8 Women's
