I have a Shimano Deore mechanical caliper on the front as of now with a 6" rotor. My rear caliper is shot, and I am shopping around/weighing options.
I believe that my front and rear mounts are both I.S.
When I bought the Deore, it was labeled as a front caliper. Is there any reason for why I can't move the caliper to the rear (using the rear brake cable)? Are the mounting holes different in the rear? If someone knows off the top of their head, it will save me the trouble to unbolting both calipers.
I am considering the idea of going to hydro on one end. I feel as though I would be happier with the hydro up front. Is there any reason for why I would want it in the back?
I am also considering going with an 7 or 8" rotor with mechanical caliper in the front.
Assuming that my front caliper can easily be moved to the rear, I am better off with a 6" hydro front brake, or an 8" mechanical (think BB7) ?
If the front caliper can't be moved to the rear, is it worth upgrading to hydro in the rear?
Thanks.
I forgot to add, scraping the front caliper isn't really an option. I am completely broke, so I can only justify buying one caliper/rotor. If spending a bit more (versus another cheapo caliper) will make me happier in the long run, I would rather go that route.
Thanks.
