So it's like any other vehicle...
A 4 cylinder 1.5L 100 hp naturally aspirated gasoline engine might work for a compact 4-door car that weighs under 3000 lbs for basic suburban commuting with maybe 300 lbs of load (passengers), but if you want anything specific, you gotta do research and pick from what's out there?
So if I already have a certain level of fitness from riding over 3500 miles a year, and expect to be exceeding the speed cut-off frequently, and will be riding socially without the motor assisting, sometimes on trails that prohibit ebikes, I'd be best looking at something like the Fazua?
I see the updated Pivot has a BBH over 360mm, but a Levo has one around 345. It's like choosing a vehicle based on ground clearance--one with a lower CoG would feel more stable when cornering and on cambers. I recall Ibis being interviewed about why they went 27.5/27.5+ on the Mojo 3, and remember it being explained that it didn't require a geo change solution like 29/27.5+ designs did, since a plus tire bottoms out like a 27.5, and when normally sagged it's closer to a 27.5's ride height.
I see the Fezzari and YT use the new Shimano battery form factor. I am turned off by unnatural looking bulges, like on the Tazer, but the Thok Mig looks good (Ducati seemingly thought so too). Pivot seemingly hid it well with the colors. I don't mind how Canyon chose to add it. Seems Merida is updating theirs from external to internal with the new battery case, based on their teasers. Wonder why they don't sell in the US.
I see Pivot has 157 rear spacing, and most others have 148. It bothers me that ebikes are being made to make use of the supply of weight conscious stuff, when heavier duty ebike optimized parts are being released. I'd opt for 157 since I figure it's more future proof.
I wish more brands made their bikes 200mm dropper post compatible, like a 375mm (14.75") seat tube length on M for my 30" inseam. This is probably my biggest wish, but realize that a saddle can only go so low with telescopic droppers, before it touches the tire on bottom out, unless the STA is steep, rear wheel is downsized, or the CS lengthened.
Figure that there's way more innovation to be had, and only really seeing it focused on certain parts, as if bikes were still seen as hot rods, rather than complete vehicles. Motors keep coming out, with Revonte, Forestal, Sachs, new Bosch (using a standard chainring), TQ, Panasonic, Mubea, Continental, and what else...
