Background on this issue. In Winter of 2017-2018, I left the bike in a cold garage (previously it was stored inside), when I looked closely at it in January, the forks seem to be compressed and stuck that way. In March, I had a LBS look at it, they indicated the fluid had inverted in the fork.
I am mechanically inclined and am in the process of rebuilding that same fork. The air side went great. On the damper, I replaced all the seals. On the rebound piston, there is a single metal ring (similar to a piston ring). Should there be more to this seal than that single ring? The rebuild kit came with a replacement, but seems bigger than the one that came with it I am going to double check this tomorrow.
I am likely over-thinking this, but I wanted to make sure that this is correct before I add the oil.
Thanks for any insight on this.
