Question on best bike for my desires
498 Views 6 Replies 5 Participants Last post by  dogonfr
I used to mtb about 12 years ago and then moved into road cycling. Now I am keen to move back to mtb. Since I live in Switzerland and the Alps are only 1 hour away, I figured it is time to get off the roads and into the woods again.
I am 183cm (6 foot) and about 80 kg (180lb) and 36 years old. I want a more upright and comfortable riding position that will allow for longer rides and multi-day rides. But I also want a bike that can climb well and handle the ride down as well. Thus, I was looking at All Mountain type bikes. I heard that XC bikes are more "race" position and are stretched out (this is not interesting as my road bike has that position and I am sore after a few hours).
I am not looking to do the "free ride or mjr downhill rides" but I do want the ability to climb, descend fast and take a few small jumps or grab a bit of air if the opportunity is there and finally something that is comfortable to ride for 60 - 100km ( 30 - 60 miles) a day.
Given that, is a XC ride or more AM ride going to be better suited. What are the key things to look for in Geometry - what really shows the difference in position from Race Position to Upright Position (seat angle, top tube length, ????). Can a carbon bike handle down hills easily enough?
For instance I was looking at: Yeti 575, Mojo SL and Santa Cruz Blur LTc. I believe I can build each of those to be under 12kg (26.5ob) - without going stupid with the weight cutting measures.
Finally, what is the difference between XTR AM and XTR XC type components. I thought that XTR was XTR and that was it. In road Cycling you have the highest level of Sram or Shimano but no differences for different types of riding (XC, DH, AM). So I am kinda lost with the comps on MTBs.
1 - 7 of 7 Posts
AM is a term I believe C-Dale came up with quite a few years back. Today the term AM is completely clueless so it depends on what you consider AM.
Do you want a bike that climbs?
A bike thet rides fire roads?
A bike that descends?
A bike that looks cool?
A bike that rails the rough?
A bike that can launch the Grand Canyon?
:crazy:
:crazy:
Thanks Dogonfr for the clarification. I understood AM was a term that meant a bike build that could do all the above (besides launching the Grand Canyon and maybe looking cool).
I would like a bike that can:
Climb
Ride roughs and Fire Roads
Descend decently given confidence levels (no full body armor and speed descents) :)
Is that such a build that can do more than just one thing? What would such a frame be called if AM is the wrong term?
your roadbike should be comfortable for hours on end in the typical roadie position. maybe you need a better fit?
a bike with a upright position will wear you out much faster than a well fitting bike that distributes your weight more evenly.
it sounds like you want a comfortable, balanced bike. not a race bike, not a cruiser. a middle ground, "trail" bike if you gotta call it something. if you go into a shop asking for a real up right position, you're going to get something you really dont want, or a bike thats really too small for you
nice question. i am very intrested in what comes up. however looks like his wallet is fatter than mine:eekster:
what would be in the $500 - 700 rangeMAX. also what should one look for in a bike like this eg... frame design, stem length. min component etc.
schlange said:
For instance I was looking at: Yeti 575, Santa Cruz Blur LTc. I believe I can build each of those to be under 12kg (26.5ob) - without going stupid with the weight cutting measures.
Two awesome bikes if I had to pick between the 2 575 would be my choice. :rockon:
Good AM reading http://forums.mtbr.com/showthread.php?t=199006
1 - 7 of 7 Posts
