1 - 12 of 12 Posts
· Registered
it's performed by twisting the adjustment knob atop the L strut. given you need to turn it multiple times to make significant adjustments (eg: 4~6 full turns) you need to stop to do this, and not on-the-fly.
· Weird huh?
another opinion
On the 05 forks, the above responses are correct. BTW for the air springs, you do not need to unweight the fork, for the spring, yep.
Now the 06 is a different animal altogether. It's lift-up turn thingy is made of aluminum and can EASILY be turned while riding....up or down. That's the air spring mind you, not sure if the coil springs are more difficult. I had a 03? Psylo U-turn with a coil, it could be lowered on the fly, but was very difficult to extend the fork without unweighting the front.
I'd skip for the 06 if you can. It is the same internals I believe (someone with more skills enlighten me), but the paint, outside shape, knobs are better.
Cheers,
Mike
· Weird huh?
oh yeah...
forgot.........on the lift up turn thingy on the 06 models, anyone else noticed it's edges are a bit too sharp? I put a few wraps of hockey tape around it cause it was skinning my already cold numb fingers.
· Save Jesus
Discussion Starter · #6 ·
Sorry, I do not understand this response. So to clarify, on an 05 Reba (which is an air version), is it possible to change travel while riding the bike?
· Bite Me.
beanbag said:
Can you upgrade a non U-turn fork into a U-turn one? And what parts would you need?
Answer 1 - you can adjust the U-turn on the fly easily - the wind down just compresses from rider weight - to extend the travel you do need to unweight the front end a bit (small wheelie) to allow the fork to extend - easily done. Answer 2 - the U-turn has completely different internals than the Dual Air and to swap out would be more than the price of the fork. '05 U-turns can be gotten pretty cheap now.
1 - 12 of 12 Posts
