I do most of my own work on my bike, including derailleur adjustments. I just have one issue I can't seem to find a difinitive answer on. I have no problem setting the high and low stops and indexing on the rear derailleur. The question is on the b-tension adjustment. I have a X9 RD & SRAM's guide says to set the space between the upper derailleur pulley and the rear cog at approx 6mm. For some reason my bike shifts much better with a greater gap. 8-10mm. As a matter of fact, I will get a slight vibration if I have the gap set to 6mm and it goes away as I increase the gap. I have a 11-34 XT cassette and 32-22 dual chainrings up front with a 50mm chainline on my Yeti 575 just for reference. Is the 6mm spec just a guide to get it close or should I stick to that gap? Am I just being too anal about this? Any advice would be helpful.
Thanks,
J
Thanks,
J
