What do you mean by "where they are?"michaelo said:
What do you mean by "where they are?"michaelo said:Not 29er topic.
Why are disk brakes mounted where they are? Is it cosmetic, reduced crud into them, reduce dive or for best braking performance?
Was just wondering if there was a logic to it
More likely to get hit by rocks in wayward maneuvers using your locations.michaelo said:on the front of the fork vs the back, under the rear chainstay vs on the seat stay, or some other bracket arrangement.
On cars it is for better coolingmichaelo said:Most cars have the the front brakes in front of the axle. (don't know why?)
Is this for a reason or just happened that way.
meat tooth paste said:Retrotec mounts the rear disc caliper on the chainstay. The first generation Santa Cruz Chameleon had the disc brake mount on the underside of the chainstay:
No, "most" cars have the disc caliper mounted behind the axle, at least on the front wheels.michaelo said:...Most cars have the the front brakes in front of the axle...
great notion once we have more room between dropouts:thumbsup:Soupboy said:Some older frames used a 22mm (?) Hayes rear brake that mounted on the top of the chainstay.
How about dual front brakes run off the same master cylinder at the lever?
Maximizes heat dump and shorter radii mean less contact with icky rocks?
