Are you running a 80mm or 100mm travel fork? What are your likes/dislikes about the fork you selected for your ride? If you had to do it over again, what travel would you pick?
2003 17" El Fuego, bearings not bushings. I suppose the travel on the shaft doesn't actually "increase", as a 2" shaft is a 2" shaft no matter what your geometry is, but the leverage on the rear triangle feels significantly different. Talk to Sherwood, or email him, and I'm sure he can explain the exact physics to you. If you look deep in the forum archives there are threads on switching from 3" to 4".dbitondo said:What Year Fuego are you riding .My Wifes Bike is an 01 and I was told by Teresa at Ventana that the 4 inch Rockers from my 04 Salty will work on the Fuego but the Travel will not increase .Just curious
db
Travel will increase, but only by .15" (from 2.85" to 3" using our bearing Saltamontes rockers) as the leverage ratio on our bushing fuegos was 1.9:1, and the leverage ratio on our bearing Fuego frames is 1.5:1, and Saltamontes frames is 2.0:1. Your new travel would be 1.5"stroke x 2.0:1 leverage ratio=3.0" travel.dbitondo said:What Year Fuego are you riding .My Wifes Bike is an 01 and I was told by Teresa at Ventana that the 4 inch Rockers from my 04 Salty will work on the Fuego but the Travel will not increase .Just curious
db
