1 - 7 of 7 Posts
say the height of my headtube, headset, and stem is a little less than 1/2 inch taller than my steerer tube, if the headset bolt is long enough, will everything work out?
notabouttoseeyourlight
that's a bit much for stem overlap IMO... Can you run your headset without the dust cover on the top? Might be able to get a little more steerer out that way.
Glad to Be Alive
take a PIC, but it sounds like you should get a new steerer.......not worth it if you take a big jump and it fails because it is a tad short
Discussion Starter · #5 ·
I can't take the dust cover off, last time I did that I had noticable movement in the fork unfortunately. I might be able to tighten up the assembly a bit to get maybe another mm or so, but not much. If it works then something like 3/5 of the stem would be grabbing the steerer. I can't take a pic because I don't have the fork, I'm just thinking of buying it,
How much does marz charge to install a new steerer?
1 - 7 of 7 Posts
