do manitous forks suck/freeze in cold weather---50F degrees or less?
its just wierd cause last winter, my friends fork just froze up until the weather warmed up again...i hear it happens on dorados..thats why they dont race them on snow races in cold weather..IMODJrider04 said:I rode my 02'Blackcomp last year in 30degree weather....was fine, just made the oil sounds a bit.
I'm not up on the internals of a Dorado, but I highly doubt they have elastomers or MCUs. Unless an appreciable amount of water had somehow gotten into the damping system, it's hard to figure why a Dorado would just seize up strictly because of temperature. Some of the older Manitous that had elastomers and MCUs for springs would get hard as a rock when subjected to really cold temps. I wouldn't think Manitous of the more modern era would be any more susceptible to cold temps than any other modern fork, but as I said, I'm no Dorado expert.Master_Jako said:do manitous forks suck/freeze in cold weather---50F degrees or less?
ok, thxTNC said:I'm not up on the internals of a Dorado, but I highly doubt they have elastomers or MCUs. Unless an appreciable amount of water had somehow gotten into the damping system, it's hard to figure why a Dorado would just seize up strictly because of temperature. Some of the older Manitous that had elastomers and MCUs for springs would get hard as a rock when subjected to really cold temps. I wouldn't think Manitous of the more modern era would be any more susceptible to cold temps than any other modern fork, but as I said, I'm no Dorado expert.
that seems like a good reason why they dont use them in cold temps...zedro said:i would say if there is a problem its probably because they arent oil bath, but rather lubricated by grease. The grease probably doesnt do a good job of displacing moisture, especially if its not well lubed or dirty, and then will freeze or get sticky. Also the grease may get too viscous at such temps. I would probably look into a different lubricant when using it in really cold temps.
theres i reason i'll only stay with open bath forks; i'll take the extra weight and forget the complication; I dont know much about Manitous. Grease and dirt can do nasty things thoughezweave said:Apparantly the fork had so much grease in it that the valving and other internals were stuck open. I am sure this was an MCU fork as well. (As an aside Zedro does this sound familiar/or realistic?)
