Not that I know of. Some hubs can be swapped in between, but that probably wouldn't be a cost effective upgrade.
No. You need to match the fork mount with the proper hub type. In other words if you're doing this in stages you should get the Pike and let it sit until you have the means to get the proper hub. BTW some hubs are convertable, I.E. DT Swiss, Hope, Hadley.Are there adapters that I can use to mount a 20mm TA hub to a QR fork?
Not in the way you are probably thinking, however there are a few companies that offer hubs that can be converted between the various front axles systems. The 2 offhand that I can think of are Hope and King- the better value in this instance probably being the Hope Pro2 (I just picked one up). You can buy this hub with the QR axle then when you're ready you can get the 20mm converter kit for, I think, around $30.bryguy6631 said:Ok, so I want to eventually get an RS Pike which uses a 20mm TA. I currently have an SR Suntour Duro which uses a generic quick release. I want to do this upgrade in stages instead of dropping 600+ all at once.
