i have a pair of hope minis and they need a little fluid. The manual says they need dot 5.1, i went to my lbs and they said they have never heard of it... where can i get some?
are you sure???????? cuz i don't want to screw everything up...Jm. said:Dot 5.1 is very rare, a motorcycle shop *might* have it, but even there it is very rare to see it.
Dot 4 and dot 3 are compatable with dot 5.1. You DO NOT want dot 5 though.
You usually have to order dot 5.1 from hope. Dot 4 is the best replacement, although there are very good dot 3 fluids out there that exceed the baseline dot 4 specifications.
yes, he's correct. The main difference between DOT 3, 4 and 5.1 is the boiling point (higher number equals higher boiling point), but 5.1 shouldn't be necessary, and the only possible consequence is performance, but i highly doubt the Hopes reach temperatures high enough to truly warrant it.thebikedoctor33 said:are you sure???????? cuz i don't want to screw everything up...
most likely they did not bleed it properly and there is air still trapped in the lines. It most likely needs to be bled; i'd go back there and ask them to touch it up gratis.dhracer1067 said:when they absorb moisture will that make them feel more spongy when you bleed them. cause i got my brakes blead like 4 weeks ago at my bike shop and they are good but still a little spongy. you think it could be the bottle of fluid they used had been sitting there for a while. havent really felt my brake lever in a week or so so i forget if they are kinda bad or not but i felt someone elses hayes mags and they were just like totally solid. no sponginess at all. thats how i want mine to feel.
well i mean is fine. it doesnt matter at all to me. but the other ones i fell were just like rock solid with the perfect amount of pull and everything. its too much trouble anyways. id just bleed them myself but i dont have any fluid. well atleast new fluid. only crap i have is like a year old. too bad mechanical discbrakes arent very good. im too lazy to be messin with fluid and bleeding and all that stuff involved with getting hydros workin right. i can set my pistons back in and change pads and move my lever around but i dont really care to do anymore then that.zedro said:most likely they did not bleed it properly and there is air still trapped in the lines. It most likely needs to be bled; i'd go back there and ask them to touch it up gratis.
well, when they're bled right, they can hold upto two years. Its just a matter of getting right.dhracer1067 said:well i mean is fine. it doesnt matter at all to me. but the other ones i fell were just like rock solid with the perfect amount of pull and everything. its too much trouble anyways. id just bleed them myself but i dont have any fluid. well atleast new fluid. only crap i have is like a year old. too bad mechanical discbrakes arent very good. im too lazy to be messin with fluid and bleeding and all that stuff involved with getting hydros workin right. i can set my pistons back in and change pads and move my lever around but i dont really care to do anymore then that.
