I checked FAQ on this site, ParkTool.com, and Sram.com and i couldn't find any info to address my specific question.
I have a set of 6-Bolt rotors. The bolts came with a set of flat washers. Do I need to install the washers or are they included to be used as a shim of some sort? If I am supposed to use the washers should they be installed between the rotor and the hub or the bolt and the rotor?
My only other disc brake wheelset is centerlock so I don't have anything to compare.
Thanks in advance!
Thanks in advance!
