1 - 9 of 9 Posts
I have a Hope sport front hub and want some new 20mm thru axle forks. Is it possible to convert my current hub to take the thru axle or do i have to get a new hub which is compatible with the fork? Please Help!
can an elephant do a chicken :D ?
sorry, i just had to
the answer is no. you can go the other way around, but there is no way in hell
you will put a 20mm axle into a 9mm hole
...idios...
"i just made a complete full of myself, havent i?
now that ive read your title, i can honestly say i dont know
Hahaha!! Respect, man! You could have just gone back and edited your first post, although then we wouldn't have the pleasure of your most eloquent, although, of course incorrect, 'elephant/chicken' comparison.
To the OP, as far as I know, the only difference between the QR20 and the 20mm bolt-on is the axle itself. As long as the hub and fork will accept a 20mm axle, you can use QR20 or standard 20mm.
And I'm still laughing...
Banned
Here's the deal: It depends on whether Hope makes a conversion kit for your hub.
Hope makes a 9mm to 20mm conversion kit for the Pro II and bulb (I think) hubs that allow you to go from a QR up front to a 20mm Thru axle. I have a set of Hopes and am doing the switch over next week.
Having never heard of the Sport hub, your best bet is to fire off an e-mail to Hope and see what they say. Worst case, you end up buying another hub/wheel.
...idios...
This thread is not about standard quick release (QR)...
White Line Black Monochrome Grey
It's about the 20mm bolt-through hub systems which are typically, but not exclusively, found on DH/FR bikes.
Bolt-on 20mm axle....
White Line Black Grey Monochrome
QR20 axle...
Line Rectangle Cylinder Silver Nickel
No conversion is required to go from QR20 to standard 20mm on a 110mm x 20mm hub.
1 - 9 of 9 Posts
