1 - 5 of 5 Posts
I want that one
Hi all,
Just mounted a new to me (very slightly used from ebay) 06' F100 RLT on my Flux and noticed that is squeaks when rebounding. Is this normal? It does it when open or locked with light treshold. Every thing else seems to work fine, tracks very nicely and feels nice n' plush. I have it setup with 75 psi for a 160 lbs rider, 20 mm of sag and rebound 5 clicks from full slow.
Thanks, Peter.
EDIT: Sorry, just read the whole thing before shooting a reply from the hip. I'd lube the QR first, just to see if the easy fix doesn't solve it. Then try oiling the stanchions and cycling the fork a few times. If that doesn't work, you might have to open 'er up.
Yep, mine squeaks too
My 06' F100 RLT squeaks a little bit on compression but it is not that noticeable.
I weigh 172 lbs with gear and run 70 lbs (on my Fox shock pump) to get 95mm of travel. Most rides I only get 90mm of travel out of it. I haven't changed the oil yet so I am hoping it will get a bit smoother after that.
WIRVNTANASHRSH?
I think this is normal. I've ridden on a bunch of Fox forks (Float, F100, Talas) and they all make some sort of noise. I would describe it as more of a swish than a squeak though. Just feel lucky that your doesn't have a loud creak (yet).
oh ya... how could I forget the mandatory response to any Fox fork/shock problem: Send it to push!
climr
I want that one
Discussion Starter · #5 ·
climr
i guess you could call it a swish, kind of a squeaky swish maybe.. i guess ill wait till i get the creaks and then service it :)
thanks for the responses
1 - 5 of 5 Posts
