1 - 5 of 5 Posts
· Registered
i noticed in the instructions from the enduro site upon installation of the wipers, put the foam ring, put the seal, then the wiper. it does not say anything about soaking the foam rings on fluid like the ones for the OE fox wipers. is it really the case? i'm installing mine and wanted to know if i just leave the foam rings dry or soak it up with fluid. thanks!
btw, fork is 32 talas fit rlc. if it makes a difference.
· Registered
Motor Oil only on the air side!
You can use Motor oil on the lower of the oil side, not the damper side, believe me, I know it from experience. :rolleyes:
Also, if you want to save, use gear oil, 80W instead of fox float fluid.
Torco RSF medium is the one fox resale as the suspension oil, for the damper side.
1 - 5 of 5 Posts
