1 - 2 of 2 Posts
Has Anybody Tryed Python Tubeless Ready Tires?
Also Thought I Saw Somewhere That You Need To Inflate Them W Co2 To Activate The Sealant??
I Usually Use Stans W Good Results.thanks For The Help Rick
Can't comment on the tires....
but I don't know of a sealant made that it is recommended that you use CO2 with. Most recommend against it! There could be a sealant out there that requires CO2 to "activate" it I suppose. But nothing I am aware of. Stans tends to solidify when exposed to CO2 and become ineffective. That's assuming a complete inflation with the stuff. I've used a quick shot of CO2 to get a Stans treated burped out tire reseated on the trail and then finished inflation with a frame pump with no problems. But a full fill isn't a good idea.
So if you try the tires just run em with Stans and forget the CO2.
Good Dirt
1 - 2 of 2 Posts
