1 - 5 of 5 Posts
a tight kick sound
I go:
Pyre set up
Rider height: 5' 10.5"
Frame size: Large
Rider weight: 188
Rider w gear: ~195
Shock: RP23
Shock settings: 1 no-propedal always; rebound three clicks towards fast; 185 psi for long extended climbs, let about 12-15psi out for DH. BRaaaaaap!
*Edit*
110mm stem, 440mm seat post, 175mm cranks
Great idea
Here's my spec,
Rider height: 6' 3.5"
Frame size: XL
Rider weight: 210lb
Rider w gear: 220 ish
Shock: Currently Float R high volume, minimal propedal setting, Also have Manitou X3
Shock settings: Float has 170 lbs, rebound is a couple of clicks in from fastest setting. Can't remember what my X3 is at the moment.
Also of note I run a 90 mm stem
Rider height: 5'10" - 180 cm'
Frame size: M
Rider weight: 210lb - 95 kg'
Shock: Float RP23 low volume, 1 no pro pedal 150 psi
90 mm stem, 410 straight seat post, 175 crank
grade A procrastinator
:) I'll go..
Rider height: 6 feet 2 inches
Frame size: large
Rider weight: 170
Rider w gear: 181
Shock: Manitou Swinger X3
Shock settings: SPV platform - full open, Rebound - 14 clicks, 85 psi
Stem: Currently running an 80 mm and can't wait to get out and ride with it.
ron
1 - 5 of 5 Posts
