Dwad said:
XTR cables are not coated.
Overpriced junk.
Cheapo housings and coated cables are the far better choice for durability. Forget the cable ends that come in the kits use shrink tubing, it at least keeps out the water.
You don't lube coated cables, you run them dry.:thumbsup:
Ever look at an XTR chain and a XT chain? They are the same, the only difference is the XTR chain is taken from the batch that had a close tolerance on the pitch. Thats what your paying for. Personally none of my sprockets are in such good condition to pay double for a close tolerance pitch chain.
Mud will do that.
Dry nylon coated cables are the best advancement in cable technology since spelting was replaced with epoxy potting for cable termination.
Its y2k gents, join the revolution.
Here's the cables I buy, the housings are a ripoff but the cables are truly superior to steel....no stretch EVER. They get a shot of dry PTFE release agent when they are installed and thats it. Have yet to replace a set, they last longer than I keep a bike.
Can't solder these ones.
http://www.powercordz.com/catalog/
