in your tubes??? I thought it was only for tubeless hence notubes.com???
Me too. But I've seen too many people have dumb issues with tubeless in general.mrrp said:I thought it was only for tubeless hence notubes.com???
Perhaps you confused the advice? Use either slime tubes, or runs Stan's No Tubes System (rim strip or tape, special valve & latex) in either regular MTB tires or UST. If you are careful in sharp, rocky terrain you should be able to get by with Stan's System in non-UST tires. Works like a charm in most places - including deserts with thorns and goatheads.jubilee said:It has been advised to me that I use slime tubes OR put stan's sealant in my tubes.
If I use stan's, how much should I put in each tube? Does it work well?
I've read terrible things about the slime tubes.
Any other advice? Thanks!
You're not the only idiot!sportsman said:c'mon Jubilee...
Feel free to say that I'm the idiot that has put stans into tubes
I use stan's tubeless when I can, and I've had no problems with it. But, I like to use mutanoraptors, and I have a 2.5 weirwolf, on my fronts, none of which are recommended to use with stans tubeless. And I ride in areas with cacti. So, rather then use slime sealant, I prefer to use stans. It works well as a sealant. I use about 1/3 to 1/2 of what I would add to a tubeless system.
If I had more money, I'd use the tufo sealant. That stuff is money...
True story here. I've been competing along time...starting using Stans (as extra protection in UST tires) in '02. Went 3 years without a flat in a race, including several 24s. My riding covers the southwest, so plenty o rocks & cacti.jubilee said:It has been advised to me that I use slime tubes OR put stan's sealant in my tubes.
Thanks!hairball_dh said:But if you have an affinity for tubes that you just can't get over, Specialized airlock tubes are damn near bulletproof for about 6 months in dry climates.
I took a look at the Specialized website and they make a sealant that they recommend putting in tubes.Scottytheoneandonly said:I would suggest thinking twice about using Stans.
I know from experience that Stan's causes some Tires to delaminate. I've seen it happen with Kendas. The last thing you want in a 24hr is to have your tire shred from the inside out!
I suggest simply carrying some type of CO2/sealant for emergencies and running a dedicated Tubeless wheel and tire.
Planning on using something, just not sure what at this point.....sportsman said:It is unlikely that you will finish two laps of this course without a good helping of sealant in your tire or tube. Less likely that you will finish a night lap.
Not sure what course we're talking about...but an addendum to the previous story...a couple years ago at Old Pueblo, during a midnight pass gone wrong, I found myself with the displeasing proposition of heading into a 4 or 5 foot tall bushy prickly pear cactus. There was no time to stop by the time my slowing faculties registered it's presence. Of course I made an attempt at a bunny hop...yeah right! I hit that thingwith both wheels, surely taking on a thousand needles to each tire.sportsman said:It is unlikely that you will finish two laps of this course without a good helping of sealant in your tire or tube. Less likely that you will finish a night lap.
ha hahairball_dh said:Not sure what course we're talking about...but an addendum to the previous story...a couple years ago at Old Pueblo, during a midnight pass gone wrong, I found myself with the displeasing proposition of heading into a 4 or 5 foot tall bushy prickly pear cactus. There was no time to stop by the time my slowing faculties registered it's presence. Of course I made an attempt at a bunny hop...yeah right! I hit that thingwith both wheels, surely taking on a thousand needles to each tire.
The HR certainly rose, but the tires didn't change one iota. Lasted the rest of the race no problem. That was with Stans inside of UST tires.
I've used stans on 2.35" tires mounted to Rhino Lite XL rims on a 5.5" travel dualie, as well as on my hardtail with skinny racing tires in long races.Scottytheoneandonly said:I would suggest thinking twice about using Stans.
