Yeah....so a few of you may have seen my post about one month ago in regards to PUSH'ing my mid-compression RP23. Anyways...I got it back a few weeks ago but didn't have the chance to ride the bike until yesterday and I can tell you that I'm TOTALLY DISAPPOINTED....
....that I didn't send it away sooner!!!!! GOTCHA!
Actually, I probably didn't fool any of you since I don't ever recall seeing/hearing/reading about someone being disappointed with the performance enhancement.
So on with the review....one ride is not a lot of saddle time but it was enough for me to notice a lot of differences. I'll follow up when I get more time on the bike
- First off, I was skeptical to be honest. I figure I would maybe feel a difference but would the difference be significant. Or in other words, would it matter. For each person, it's subjective. Since I was coming off a Mid-compression tune maybe those of you who have a Low may not feel the same performance differences. This really applies to those of you who have a Mid or even the High
- I got the PLUSH tune because I wanted the most supple small bump compliance
- Weight: ~173 (riding weight). Old settings on the RP23 was ~147 PSI. At this setting I would bottom out during the ride but never too harshly. It may be a little low from the "advised" setting but I could not tolerate the small bump harshness if I went any higher. To me the bike didn't perform well enough on the stutter type terrain or climbing ( way too stiff ) with higher PSI and I would still bottom it anyways (thus the lack of midstroke support).
- When I bolted the shock on, during my "parking lot" test, I immediately noticed how much more compliant the shock was....rebound was also much much smoother, a benefit I wasn't even planning on or even thought about. Oddly, I was surprised that I had to run MORE air in the shock to achieve the same level of sag (~153 or so). I had read that most riders were able to lower the PSI because of the tune. More on this later......I also messed around with the PP settings but the settings were not very distinct....much more vague than pre-tune. I never really use the PP so I just noted this in the back of my mind and would develop an opinion about it once I actually rode it.
- The ride: So I went to Waterdog yesterday which I have rode extensively so I know exactly how the bike reacts. The ride starts off climbing and immediately I notice that all the trail chatter was so much smoother. I was shocked at the level of difference. I kept looking down at the shock and it was definitely way more active. On smoother parts, the shock definitely moves more than previously but you don't really feel it. So as of right now, I'm stoked....a little confused though since I was running HIGHER psi. To give you an idea of what this may feel like....it's as if you lowered your tire pressure about 10 PSI....all the smallish bumps were just muted. Or maybe another good analogy is like adding an extra 1" of travel to your bike.
PP settings: I flipped the shock to #3. Noticed a difference but not nearly as stiff as pre-tune. I still probably won't use it. PP to me is almost irrelevant on the Mojo.
- DH: Totally different. Running down the rougher sections (top part of Rambler) and the lower "creek" section were a total blast. The bike doesn't get bucked around nearly as much and keeps a much tighter line. I run a Lyrik U-turn and the fork ALWAYS outperformed the shock in every aspect. Honestly, the shock is giving the Lyrik a run for the money now. It definitely feels more balanced eventhough I have more travel in the front (I always run the Lyrik at 160). Again, the bumps just feel much more muted....like you were running really low PSI in your tires or added 1" of travel to your ride. I had to stop a few times just to check the tires and even to check the air pressure in the shock jic it was leaking air or something. I just could not get my head around the shock being so plush when I was running MORE psi. I was confused and shocked at the difference.
- I never bottomed the shock....had about .5 cm more to go according to the O-ring whereas I bottomed it previously. So back to the PSI thing. I figure before, I would have to run a much lower PSI to achieve the small bump performance I could tolerate. Yes, I would bottom more but it wasn't harsh so it wasn't lacking in that area. With the PUSH tune, the shock was definitely more active in the first 1/2 of travel even with more PSI but offered more midstroke and bottom end support so as not to bottom out.
I'm going to stop with the review at this point because I am one to give my overall impression after much more ride time over varying terrain (plus it's Xmas and I really have to be doing other things!!! hahah). I really want to test the shock on the deeper travel performance so I really need to take it to Demo/JMP/or the "other" one.
I also want to tweak with the air pressure as well....maybe going down to 150 to see how far I can push the small bump compliance w/o sacrificing bottom out control.
For those of you that have a Mid Compression RP23 and want a more smooth, more fun riding bike, and looking for a plusher ride should definitely think about this...scratch that. JUST DO IT! I was really skeptical and even after the purchase, I was feeling some buyer's remorse because I was debating PUSH'ing a VAN R. I'm totally happy with my choice and am eager to push the shock even harder on more difficult terrain. To me, this is how a rear suspension should perform.
Although, I am still really curious how it compares to a stock Low compression tune.
Oh and MERRY XMAS! I know what my gift to myself was!
