I have a 2003 rm slayer... is it worth the time and money to send in my 2003 fox float RL into push to get it over hauled or would you just buy a new rear shock..I want a more efficient ride for climbing and smoother on the down hills thanks
Yes, this is part of it. You need to measure the center of the mounting eye's of the shock. You will also need to know the stroke of the shock too. The stroke is the total compression of the shock. To measure your current shock's stroke, let out all of the air and then compress it completely and measure the eye to eye length. The difference between the two eye to eye measurements is the stroke.norcalruckus said:You have to measure the eye to eye. That is how most conventional shocks are measured.
