1 - 3 of 3 Posts
I am new to mountain biking. We have a lot of trails near my home, and I am hoping to ride in the Xterra Epic (a triathlon with a 30 mile trail ride) at the end of the summer. I do not have a bunch of money to throw at a new bike, but I want a bike that I will be able to use and be happy with for a couple years. I currently get a deal for 40% off diamondback (don't start screaming yet). Please take a honest look at the component list before replying. The bike i am considering is the OverDrive Comp which cost $720 (MSRP $1200). I would like to know if this is worth considering....Thank you.
Frame: Overdrive 29" Butted 6061-T6 Aluminum w/ Formed Top / Down Tube, 1.5" Tapered machined headtube, forged drop outs w/replaceable hanger, disc only
Rear Shock: N/A
Fork: Rock Shox XC 30, TK-29" w/turn key lockout, 100mm travel, ext. rebound, compression adj.
Headset: FSA No.42 , Sealed ACB for Taper Headtube
Cranks: Shimano FCM522 Dyna-Sys 10spd Crankset 24/32/42t
Bottom Bracket: Sealed Cartridge
Front Derailleur: Shimano Deore 10spd, Low clamp, dual pull, 34.9
Rear Derailleur: Shimano Deore 10spd Shadow type
Shifter: Shimano Deore 10spd Rapidfire
Cog Set: Shimano HG62 10spd Cassette (11-36t)
Chain: Shimano HG54 10spd
Hub (F): 32h SL-7 Alloy w/ CNC Disc Mount
Hub (R): 32h SL-7 Alloy Cassette w/ CNC Disc mount
Spokes: Black 14g Stainless Steel
Rims: 32h Diamondback SL-7 Doublewall
Tires: WTB Wolverine Comp 29x2.2
Brakes: Shimano BR-M445 Hydraulic Disc w/180mm frt / 160mm rear Rotors
Brake Levers: Shimano BR-M446 Hydraulic
Pedals: Wellgo Alloy forged, CNC MTB
Handlebar: DB Lazer Series 31.8mm low rise
Grips: DB4L 135mm Kraton
Stem: DB 3D Forged 7° 31.8mm
Seat: DB Race saddle
Seatpost: DB Micro Adjust 30.9mm
Extras: DB Key Chain, Owner’s manual, H20 bottle mounts, Chainstay Protector, Clear Coat, 3 extra inches of wheel diameter!
Discussion Starter · #3 ·
I have not had a chance to ride it yet. I was curious if the compents for the price range are garbage and need to be replaced, or if they are suitable. I wasn't sure if this bike should be on my list for consideration.
1 - 3 of 3 Posts
