1 - 3 of 3 Posts
Ok another new guy question... I just found out, havnt ridn yet, that I have to put air in my shocks.. Anyhow Will a regular mini pump work as long as it has the schrader head or do I need to purchase a separate "shock pump"?
They are different from tire pumps. They are low-volume but can handle higher pressure. I think most bikes with air suspension come with one from the manufacturer. If you buy, get one that has a built-in gauge.
A regular tire pump cannot produce a sufficient level of high pressure to effectively fill the suspension shock air chamber.
You will need a Bicycle High-Pressure Air Pump / Shock Pump designed specifically for your need.
Typically High-Pressure Air Pump prices range between $25-$35.
e.g.:
> Shock pumps available from Jensen USA: http://www.jensonusa.com/store/sub/...&sort=Default&show=25&pricemin=0&pricemax=100
You may also want to then visit the suspension manufacturer's website for set-up instructions, helpful guides, along with useful maintenance and service information.
e.g.:
> For Fox Racing Shox Owners: http://www.foxracingshox.com/fox_tech_center/owners_manuals/010/eng/index.html
> Using the Fox High Pressure Pump: http://www.foxracingshox.com/fox_tech_center/owners_manuals/010/eng/index.html
Hope this helps.
1 - 3 of 3 Posts
