1 - 4 of 4 Posts
There should be a cap on top of the fork you unscrew to reveal a valve. Then you use a Shock Pump, to pump in the right amount of Air based on your weight. You should be able to find a pump at your bike shop.
Here is an example shock pump.
http://www.jensonusa.com/store/product/PU707C00-Manitou+Shock+Pump+W+Gauge.aspx
Here are links to the Tora Owners Manual:
2006: http://www.sram.com/_media/techdocs/06Combo32_English.pdf
2007: http://www.sram.com/_media/techdocs/07 Tora and Recon User Manual_RevB2Rotated.pdf
1 - 4 of 4 Posts
