So far the only solution I've come up with to carrying my Pugs is to use a dangly-style reciver mount rack. In general, I don't like those kind of racks, because it is hard to carry bikes with odd style frames without special adapters, the frames want to hit together, the bikes hang too low when crossing gullies off road, etc, etc.
In short I'd like to be able to carry my Pugs on a roof rack. The problem is that the fork is 135 mm so it doesn't fit. I think someone with a machine shop could make a longer roof rack skewer plus a tubular 35 mm spacer to install on the right side of the rack. The spacer could be slid inwards to fit a pugsley fork and slid to the outside of a regular fork. An oversized toe strap should hold the rear wheel on fine.
Does anyone have interest in making these parts or do you know someone who would want to do it?
I'd like to see a wider wheel tray that could fit in my SportWorks rack as well, but that would be a little bit more of a challenge to make a tray that would fit tires from 4 inches down to 1 inch wide road bike tires. I think it could be done, though.
