1 - 9 of 9 Posts
just bought a conti gravity ust 2.3 for front use on a cannondale prophet. conti's website recommends 50psi. is this possible? me - 160lb, s.florida (roots, sand, little hardpack), 1.5 scoops stan's.
Premium Member
I hear ya - mine state a min of 30psi....but after two rides on top of something akin to a twitchy monkey I dropped it back down to 24psi. No pinch flats or popped beads.
BTW - I run Spec Adrenalin 2.0 tubliss w/ 1/2 cup of Stan's on Crossmax SL's. And I also weigh 160
Singletrack Addict!!!
Hey shiggy I have the vert's with slime in the xm819 so far no prob, but was interested in using latex based, why did you reccomended to the gravity user to loose the stan's?
Premium Member
Do a search for "DIY tubeless"
Discussion Starter · #6 ·
thanks to all so far. shiggy, if i skip the stans, should i use any sealant, or just run the tire dry? also, what pressure would you recommend starting with before fine tuning. i'm also on mavic 819. thanks in advance.
Premium Member
If you are using UST tires and do not ride in areas with thorns there is no reason to use a sealant. If they are standard tires inner tubes work best.
35psi is a good place to start.
Discussion Starter · #9 ·
nevermind
thanks for the help, but i went back with my high roller ust 2.3 for the front. that conti gravity ust wasn't working anywhere here in south florida. my old high roller is still better than the new continental. i'll never be disloyal to maxxis again. any word on the ignitor ust 2.1 for the rear?
1 - 9 of 9 Posts
